cyberpunx
Wiring a gps1240 Help anyone assist me.??
Hi all im currently trying to wire up a navman gps1240 receiver to my new navman vhf 7100
i know it can be done with a different receiver see here:
http://cgi.ebay.co.uk/Marine-GPS-receive...A1%7C240%3A1318
this is the pinout's i have for both items
first the navman GPS1240
pin 1 ground
pin 2 power input 7 to 32 volts dc
pin 3 not used
pin 4 NMEA data in (rs232)
pin 5 not used
pin 6 NMEA data out (rs232)
pin 7 not used
pin 8 not used.
and the navman vhf 7100
pin 1 red not used
pin 2 orange NMEA out + not used
pin 3 white program or clone select not used
pin 4 yellow NMEA IN + from GPS
pin 5 green NMEA IN - from GPS
pin 6 black NMEA out - ground not used
pin 7 blue navbus not used on 7000 or 7100
pin 8 grey navbus not used on 7000 or 7100
........the radio already has 12volts going into it and it's powered up this is just the extra connector to input the GPS data in and out( i think?)
here is the site telling you the data for the GPS1240 navman
SEE HERE:
http://www.navmanwireless.com/uploads/bw/XF/bwXFSygLu6-jmGy797TfJA/LA000505A_GPS1240_DataSheet.pdf
SEE PAGE 7.
i still have the LTW-8FM connector on it so i would have to cut it off but i do have the following colours for it?
GPS1240
additional colours (connector cut off) IVE NOT CUT MINE YET.
but here is the colours in case it helps you to help me.
cheers
pin 1 gnd black
pin2 7v to 32v red
pin 3 n/a n/c
pin 4 GPS NMEA IN brown
pin 5 n/c yellow
pin 6 GPS NMEA OUT green
pin 7 re prog -5v white
pin 8 n/a n/c
anyone help me out here.
is this possible to do so i can use it with that gps and it would A: give me my DSC radio and B: give me exact location at all times when the radio is on.
ANY HELP REALLY APPRECIATED.
P.S thanks to all who send get well wishes to my mum thanks alot it touched me honest she is doing better now and also for those following the sinking of my boat and the re build then i will get the most current pic uploaded so you can see how she's coming along.
thanks for all the help
RSVP
ASAP
also found this dont know if it will help i still dont understand
i cant see the NMEA plus and minus on the gps 1240 only NMEA in and NMEA OUT?
SEE here?
http://www.navmanmarine.net/Navman/Templates/standardcontent.aspx?id=5285
pin 1 ground
pin 3 not used
pin 5 not used
pin 7 not used
pin 8 not used.
pin 1 red not used
SEE HERE:
SEE PAGE 7.
GPS1240
cheers
pin 1 gnd black
pin2 7v to 32v red
pin 3 n/a n/c
pin 5 n/c yellow
pin 8 n/a n/c
RSVP
ASAP
SEE here?
