Winterizing water system - what's this valve?
farmer.leo
8 Oct 2011
The big stainless steel tank is to the right, at the bottom is the feed to this "rectangle" with a Jabsco pump - the red Accumulator tank, and the closed loop with a valve in there.
Why this closed loop? What purpose does this valve serve?
I'm preparing to winterize, and intend to use a low power air compressor to blow out the lines. Not sure about this valve, and were the best place is to disconnect a water pipe and place the air compressor.
david_bagshaw
5 Jun 2001
uk
Perhaps it is to let off the pressure from the system, back to the tank, such as when you leave the boat in the week, to help the accumulator live a longer life.
