RobWales
Hi All,
The motor in my recent purchase (Bayliner 2452) is a Mercruiser 4.3 MPI petrol which has less than 20hrs running on the clock (insurance claim by previous owner due to frost, brand new installation 18mnth old) I bought the boat 4 weeks ago and since then it's been sat on chocks at the yard having some exterior fettling etc done...
As it's one of the later models from Mercruiser it has an easy "single point drain" fitted for the raw water cooling, however reading up on this system I'm lead to believe you should not not trust it to drain all the water from the risers and the block and you should also crack open each drain point to make certain nothing remains (makes good sense I think).....I then intend on filling all cavities waterways with pink antifreeze via a method found online.... i.e undo main hoses and fill until pink dripping from drains then nip up drains and continue to fill, should take approx 9 ltr of the pink stuff in total.
I realise there are other methods like running engine while fixed up to antifreeze supply through the muffs but as I intend removing the leg for safe storage over winter I think I'll go with the above.
However my question is this....
As the engine is not going to be run from now until the end of March 2017 should I worry about oil fogging the bores as I have read in some of the American advice pages or is 6 months nothing to worry about?
Any thoughts on anything relating to the content of the post most welcome.
Thanks, Rob.
Thanks, Rob.
