winterising engines in salt water
mad_boater
14 Oct 2002
staffordshire
Can anyone help on winterising engines with heat exchangers?. I have owned boats for many years mostly used in fresh water. When laying up the engines I always remove the tops off the water strainers and on tickover I pour a 25% mixture of antifreeze and fresh water into them untill the mixture apears out of the exhausts.Now I am using the boat in salt water I wonder if it is necessary to do this as salt water requires very low temperatures to freeze.
hlb
RIP
Any Pub Lancashire or Wales
Yes, you can do the same. As I tend to use the boat through the winter I dont bother. But do switch onthe greenhouse heaters to keep engines aired.
<hr width=100% size=1> <font color=blue>No one can force me to come here.<font color=red> I'm a volunteer!!.<font color=blue>
Haydn
hlb
RIP
AAaRRggggg. Well put some antifreeze in. Like I said. BrrRUuummBBeerr.
Haydn
ChrisP
21 Aug 2001
South East England
Having just spent a couple of grand on new intercoolers this is a subject fairly close to my heart. Advice from the manufacturers is to drain down all the raw water side and leave the cores open to the air for as long as possible after cleaning them. If the boat is to stay in commission replace all the "O" ring seals and rubber end caps. Then fit engine room heaters with a stat to turn them on at approx +1C. It gets kind of expensive but then so is a tow back to shore.
ChrisP
<hr width=100% size=1>What do you mean the sea gull in front's walking !!!
david_bagshaw
5 Jun 2001
uk
We use to keep our previous boat in salt water all year, my method was to run engines connected to a shore hose at tickover fro 10 min, then recirculate antifreeze before draining.
That was before wet vacs
Now if I was laying up in sea water would still rinse, then remove end caps & hoover out the fresh water from the core stacks. & then replacce the end caps , otherwise the engine antifreeze will be lost from the rubber ring seal.
Some will disagree butI have allways greased the mounting area of the core stack & its rubber ring using the grease used for front wheel drive shafts.& although it is grafite, my core stacks and the alloy areas are like new.
boat delivered 86.
<hr width=100% size=1>David
<A target="_blank" HREF=http://www.euroboating.net>http://www.euroboating.net</A>
