35mm
I'm on the south west coast (UK) and have a drying mooring on a salt water (not too brackish) estuary. I'm leaving my boat in the water over the winter, and hope to get out on her for a winter sail and spot of fishing from time to time.
My engine is an old (but reasonably good) Volvo MD1B - 10hp single cylinder, diesel with raw water cooling. I've started wondering about the safety of the engine block if the temperature gets below freezing this winter. In the past I've had outboards and haven't had any freezing problems with them as they tend to drain when left cocked. My father had diesel inboards and some times wintered his boats on the mooring, but he's no longer alive to give me his pearls of wisdom. The internet seems surprisingly sketchy on this subject. I recently purchased 10ltr of propylene glycol, for the water tank and heads, and was thinking I might have to flush some through the engine each time I run it through the winter, which would be a pain in the neck. This evening I was talking to a local fisherman friend and asked him what he does to protect the raw side of his closed/fresh water cooling system. "Nothing!" he said. "Just make sure it don't get clogged up with muscles and clams." I told him about my engine, and he said if it's raw water cooled it should be fine, and he'd never heard of any boats on the river having problems with freezing. So now I'm totally confused. Sea water freezes at about -2C and apparently it doesn't freeze the same way as fresh water. The fresh water within it starts to freeze but leaves pockets of brine which won't freeze until the temperature gets much lower. So does this mean it might go slushy, but not solid enough to crack the block? What are people's opinions and experiences of raw cooled engines left afloat in sea water over the winter?
