Windscreen seal searching
Boater On Thames
5 Oct 2018
Trying to replace the windscreen seal. Problem is that I can't find the same seal after a week of searching online. The seal is about 15mm wide by 9mm height. Any idea? Many thanks.
You need to make a drawing of the section of the rubber including the grooves' dimensions.
It isn't clear from the photos what the section looks like.
You could try calling Trend Marine. If a British boat then the chances are that it will have Trend glazing, and they will have worked with a sealing supplier.
