Window draft excluder
Jegs
7 Jul 2007
Good afternoon,
I am trying to locate a supplier for some draft excluding strips which are attached to the central vertical end of the fixed section of a horizontally sliding port - they appear to be about 6mm wide & of unknown depth [because I'd rather remove the assembly once rather than twice].
I've looked at C.A.K. tanks & Wilkes without success & Google results in items for 40 year old VW campers. If anyone could advise me of a likely source or even the correct name for the component I should be most grateful.
John G
A description of the strip might help.
If they are rubber, have you tried Seals Direct?
Thank you for taking the time to reply. I keep a catalogue from SD on the boat &, unfortunately, it does not help. A description is difficult because it is squeezed between two panes of glass & is probably 20 years old: in appearance, a 6mm strip, it resembles felt, but I hope it was something better.
John G
