jrudge
I have installed a remote controlled chain counter. ( thanks to hurricane for finding it for me ).
The transmitter is in the chain locker and I connected it to he windlass supply as it is the only supply that is there.
The windlass works perfectly but the remote goes off line when it is used.
I put a meter on it and the recorded voltage falls to 3volts or so. Bear in mimd the windless is working absolutely fine.
It strikes me as it is possible this is quite normal. There is a virtual short circuit ( high current motor ) a few inches away
It could be a loose joint ( I have checked the high current box and all is fine ) but if this was the case I would also expect the windlass to be playing up.
The solution is of course an independent power feed but the whole aim of a wireless unit was to avoid taking the boat to bits
I want to install an anchor cam as well which was going to be a remote transmitter.
Any suggestions on how to resolve or alternatively how to run a wire on a s58 2004 with least effort !
Thanks as ever
Thanks as ever
