BobnLesley
As you may recall, our Lewmar V3 Windlass stopped working a couple of weeks ago - the motor sounds fine, but the shaft/gypsy aren't turning, so today's job was to remove it for fixing/replacement. I eventually got the four nuts off which hold the motor to the underside of the deck and to the gypsy and head down on top of the deck, taking great care to ensure it didn't fall on my head; I needn't have worried, the two halves are still firmly sat where they were to begin with. I'm not sure if it's sealant or corrosion holding them together, though I suspect the latter. The manual/parts book suggests they should just slip easily together/apart and that there are no other fixings? I am hoping someone might have a suggestion better than my own for getting them apart; I'm thinking to get the biggest hammer that'll fit/swing (sadly not very big) inside the anchor anchor and belting the visible bottom end of the shaft which I can see inside the gearbox/motor unit to try and knock that up to separate them?
