Kelpie
Scratching my head a bit here and wondering if I have a duff unit. Hopefully I've simply wired something up wrongly.
I've bought a cheap remote control for my windlass, it's pretty much the same as this one: Amazon.com
My windlass is a Lofrans Tigres with three poles. I have a genuine Lofrans relay box and a hard wired switch which is all working fine. So it's not a problem with the windlass, relay, or power supply. The remote handsets have fresh batteries and the light comes on when you press a button.
The rx for the cheap remote has four connections. Positive to the positive power on the relay box, straight from the battery. Negative to the common (middle of three) on the switching part of the relay box. And the white and yellow control wires go to the other two control terminals.
If I was any good at uploading pictures I would be able to explain this better!
Have I wired it wrongly? Is it maybe a pairing issue? Or do I have a defective unit?
