So after many years (12+) of faithful service, my lofrans windlass has stopped working. I have :
Up/Down Switch : In anchor locker on straight wire which is plugged into a socket also in the anchor locker.
Relay : Simpson Lawrence 0052531 on bulkhead behind anchor locker
Circuit Breaker : Close to batteries - Lewmar 185070P 70 amp.
It all looks fairly aged/grotty, and there are some obvious changes that could be made to improve the system :
a - Remove joint in up/down switch cable.
b - Relocate breaker which currently sits in the companionway (open to elements).
For pecuniary reasons I am assuming the windlass itself is okay.
I guess the options are :
1 - Test each component, find the fault and replace.
2 - Replace all components to ensure longevity of service.
3 - Redesign according to latest standards / ideas.
At the moment my plan is set on doing a, b and 2. Is there anything in 3 that I should be considering ?.
I sail mainly single-handed and am not attracted to remote controls etc. I like to be at the anchor locker when it is all happening so I can keep an eye on stuff.
I am sure I have read somewhere that the relay is most often the culprit ?.
Any thoughts / ideas / comments welcome.
Many thanks.
Many thanks.
