Mike2309
This is from a previous discussion -
http://www.diy-wood-boat.com/images/Windvane_axis.jpg
(at least, I hope so - can't seem to paste the image directly into this) It shows 2 control lines . The upper one is clearly for the connection between windvane and trim tab to be made/unmade. But the lower one? is that just to haul the trim tab into the inline (with the rudder) position? If so could not both tab and vane be set free to go their own way, then be locked together once on course? Also what is the notch in the toothed wheel for? Text says it allows the locking lever to drop right through the wheel (when the S/S gear is not in use?) But the control line lifts it up and out of engagement so why not just leave it like that? I'm imagining that to rapidly disengage the S/S you would grab both lines, pull and make fast.
Am I just not understanding the situation?
