emandvee44
We have had a disastrous history with the Air Breeze turbine.
Our first one bought 7 years ago burned out and was just in the guarantee period. We got a replacement from the suppliers, and that did not work, and never has. The symptons are well known, lots of noise, banging and sudden stop and nothing generated. The noise is so great that the turbine has to be permanently tethered.
An online search on various forums indicates that the problem is in the pcb inside the unit. A replacement pcb can be purchased for around €250 euros, but no guarantee of a fix.
I found this:
https://www.amazon.de/ECO-WORTHY-Wi...YYE/ref=sr_1_7?ie=UTF8&qid=1541758096&sr=8-7&
It looks exactly like the air breeze, but much cheaper. It also comes with a charge controller, although I do not know if I need that.
Our current set up has solar panels wired to a Fox 320 controller, then to the batteries. A fox MD1 monitor/controller is also fitted.
The wind turbine is wired directly through the stop /run switch and an ammeter, then to the batteries.
I am wondering if there is anything wrong with the current arrangement.
Any advice would be appreciated!
Thanks,
Michael.
I found this:
Thanks,
Michael.
