Thistle
The wind speed is proportional to the rate of change of pressure.
The slope of the line on a barograph chart is proportional to the rate of change of pressure.
So I should be able to measure the slope of the line on the chart and convert this to a wind speed.
An easy way to do this would be to draw a series of lines (as diagonals of a circle) on a sheet of acetate at, say, 10 degree intervals, and to calibrate these as wind speeds.
If it's that easy, why hasn't someone done it before or am I being stupid (again!)? If I'm right, how do I calibrate the chart? What slope of line relates to what wind speed?
(I know it will depend on the size of the barometer drum but a common size has a circumference of 287.5mm for 7 days and 76mm tall for a pressure change of 100mb.)
