ATCBird
I am trying to wire up my new ST40 wind instrument and have a few wiring questions that I hope someone can help with.
1. The cable had to be cut to get it through the coach roof, can I join it with normal choc block or do I need a special connection?
2. I have a depth/speed already wired to the instrument switch, can I just wire the wind instrument to exactly the same terminals? Will the fuse be ok? Will I blow it up?
3. The depth/speed is a very old autohelm, but has a sea talk connection, can I connect this to the wind and then connect to the same terminals? Will the sea talk work as the autohelm system is so old?
4. The instructions mentions ferrite suppression, do I need to put one on? It doesn't make it clear.
5. Should I get an electrician to do it as my knowledge is so basic????
Any help gratefully received.
Tania
Tania
