stranded
Raymarine 2007 vintage windex to st60+ head. I have googled this to death and this is the last gasp before I send swmbo up the mast - which tends to be more costly than hiring a pro. So, it stopped giving wind speed - just the three dashes. As with all it problems, that could be resolved by switching off and on again. Then the direction started wandering, by up to 180 degrees. First couple of times, factory reset and relinearisation sorted it, for an hour or three. Then it stopped linearising, so I manually calibrated, which again would hold for an hour or more then wander off. It has now, sometimes, but not always, started going backwards i.e. backing when the wind is veering. And yesterday we had several 90kt+ gusts, although you would never have guessed it from the glassy sea and sedate progress. In between times, wind speed doesn't feel to be far off when I can get the direction right.
So, my deduction, after a great deal of careful thought, is that something is, in technical jargon, totally knackered. As the windex pointer points at the wind, and the cups seem to spin reasonably consistently, I am assuming electronic rather than mechanical. In which case I presumably need a new transducer? And if so, will it work with my existing st60+ display as I am a bit OCD and would probably have to get matching speed and depth displays and I can't afford it.
As aforesaid, can't find any similar symptoms online, so grateful for any suggestions.
Mark
Mark
