ksutton
Intend to install a wind generator before season starts again, probably a Rutland 913. It will have to go in the usual place, at one corner of the transom area. I can see fitting kits which you can purchase consisting of the long vertical mounting assembly tube with a fixing bracket on its base and clamps to attach a couple of angular stays to the pushpit tubing. I have not found anything to attach this vertical generator mounting tube to a horizontal or vertical pushpit tube, or even a corner bracket. I have seen some boats use stainless jubilee hose clips, but it looks a bit crude. Anybody know if there any dedicated stainless (or even nylon) clamps on the market to do this.
