homa
I sail a Monsun 31 with a pair of standard (non st) 2 speed 40 lewmar winches for the headsail sheets.
The problem I find is that due to the narrow cockpit coaming & closeness of the dodgers, I can't get a full turn with the handle and therefore unable to use the 2 ratio's effectively. The winches must have been fitted without dodgers in mind. I'm sure many boats must also have this problem.
Only way to sheet in is to crank the handle back & forth, completely negates the point of a 2 speed winch, very hard work when sheeting in that last bit when going to windward.
Have already got the shortest handle I can find, any shorter & I won't be able to turn the thing under load!
On my last boat I had a removable flap cut into each dodger, with flap removed the handle could be turned fully. However I'm reluctant to do this on present boat.
Another option would be to mount the winch on a pedestal to raise the winch handle above the top of the dodger/guard wire, (would need to raise winch at least 6 inches !)
Re-siting the winch elsewhere on the coaming will not solve problem.
The best idea I've come up with is to find a handle with a ratchet built in. Because the winch is 2 speed, the ratchet would have to have a reversible ratchet mechanism.
I'm sure I've seen a ratchet handle in the distant past on someone's boat. So far I've drawn a blank with the local chandlers.
Anyone know of where I can get such a handle or, a better solution to my problem?
Thanks in advance,
homa
Thanks in advance,
homa
