TQA
- Joined
- 20 Feb 2005
- Messages
- 6,815
- Location
- Carribbean currently Grenada
My galley worktop has two square hinged opening doors for my top loading fridges.
The base material is 5/8th plywood covered in a formica like material. When single handed I only use one fridge and did not open the other for two months. When I tried opening it, it was stuck shut. I eventually managed to open it and it was clear that water had got in and had caused the plywood to swell. As a temporary fix I removed the edging strip to get some clearance.
Will the plywood return to its original size when dried out. I am in the tropics so drying out is not a problem.
What I don't want to happen is to glue the side strip back on and refit the door only to find it has stuck again. It was a week long struggle to get it open last time.
