Wiggo
OK, so last night we limped back on one engine again and this morning the nice man from BD Marine came round (top marks for service, BTW). We can't figure this out. Disconnect the shaft from the coupling and run the engine in gear: no vibration. Bolt up the couipling and do the same and the engine has 2" of lateral shake, so that's clearly a bent shaft, no?
No. Disconnect the shaft from the coupling and turn it with a dial gauge on it and it runs true. Do the same with the flange and there's no more than 0.2mm of runout. Similar or less runout on the gearbox output flange. Slide the tailshaft onto the coupling and again, 0.2mm of runout at most. Bolt it up, and the runout increases to over 1mm. Run the engine in gear with the tailshaft unbolted (just prop thrust holding it to the coupling) and there's no vibration. Bolt it up, even just one of the four bolts, and three quarters of a ton of engine and gearbox tries to climb out of the engine bay it shakes so badly (and that's just at tickover).
So we're lost. The next thing is to lift out again, draw the sahft and get it on the lathe to check it is straight over its entire length, and do the same with the flange coupler. We seem to have a bend in the shaft, though no idea of how or why, and we can't measure it in the boat.
Ideas welcome...
Ideas welcome...
