Why so long ?
ChrisP
21 Aug 2001
South East England
Why does it take so long to fill up with fuel? With engine consumptions the size that they are and the size of the fuel tanks in average cruisers. Why do manufacturers put in such small filling hatches. Boats with 2-3 hundred gallon tanks fill through hole of around 2". I used to put 200 gallons into a truck in a quater of the time it takes to put half that amount into a boat and no fafing about with blowbacks.
If the hatch's were larger maybe the fuel pontoons could have comercial size pumps. The local BP station now has pumps where they have 2 pumping rates one for cars and one for comercials. How long before the technology hits the waterside?
What do you mean the sea gull in front's walking !!!
hlb
RIP
Any Pub Lancashire or Wales
You should have seen the problems I used to have round Ireland. Filling up from comercial refuelers or tankers. 3/4 inch nosle with maybe 3 reducers on the end and massive power. All that came out the pipe was foam. So took hours. Or diesel all over the place cept tank. Funny how even a car has a bigger inlet.
No one can force me to come here-----------
----- I'm a Volunteer!!!
Haydn
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
It's a legal thing know as the Petroleum Regulations. All vehicles etc can only carry a 2" pipe to be Pet Reged etc. Control of explosions etc. i think.
Not everything is black and white if you prove otherwise you’ll get run over on a zebra crossing
ChrisP
21 Aug 2001
South East England
Nice thought but mine are diesels for a start and anyway why should boats be different to trucks. My old Freeman had 3 or 4" fillers with big shiny screw on caps and we never had any problems filling her up.
Chris :eek:)
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
The Regs don't make any destinction I think - and it governs the size of the supply hose / pipe not your hole :)
But I take you point - high pump rate would help but then as has been said you just foam with diesel so hence the restriction me thinks.
hlb
RIP
Re: Why so long bollocks!!
Rubish!! I've filled up from 4 or five inch pipes, like I just said. They just have to put loads of reducers on the end, to go down my hole. Take a long time to fill QE2 with one inch pipe!!
Haydn
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
Not wanting to be argumentative, why then are all raod tankers that refill petrol forecourts restricted to a 2" or 3" pipe !
ChrisP
21 Aug 2001
South East England
Whilst I'm loatheed to interupt you 2 in full flight. The size is probably limited because of the pump caperbilities. Increasing the size of the discharge pipe would cause a change in the pressure ratio accross the pump and could cause flashing in the outlet pipe due to reduced back pressure leading to excess vapour at the discharge of the pipe and increased venting from the ground tanks.
I can assure you however we use larger sizes at the refinery loading points under controlled conditions and far superior safety systems.
The whole point I'm making is that if boats had the same size fillers as trucks. We could use the higher flow rates throught the existing pipes and fill faster. Or go one further and used sealed connections with controlled venting and fill even faster.
ChrisP :eek:)
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
A well educated answer Sir thank you, but if we think about it a bit, what's the hurry, not as if we're on a formular one track now is it and need 100 gals in under 10secs before the off.
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
Peter
poter
4 Feb 2002
Still going south currently in Corsica for winter
www.fairhead.com
This is cra*p
Look why don't you save the envioroment and drill a big hole in the front of your boatee, get a tree trunk & put in the hole, get some sheets from swmbo and tie em to said tree,,,,,,,,,, bit of string and use the wind. (well natural wind not whats on this thread)
There you go!
poter.
Freebee
21 Oct 2001
Alton, hants
Having just bought some kerbside type filling pumps for a work project I can tell you its impossible to buy a pump that will fill at greater than 130 L/min.
lanason
23 Jul 2001
Malvern, Worcs
Re: DONT Follow that advice
Just did exactly as you said and the tree trunck came out the bottom of the boat and the damn thing appeared to be impailed in the sea bed - Can that be why Raggies go so damn slowly.
BTW Its an illusion - boat goes nowhere and tide rushes past creating a feeling of movement IMHO. :)
Adrian
Don't call me "Ian"
Cleopatra - yellow hull called Court Jester. Have you seen her ?
