Nostrodamus
Simple question.
Why are some boats fractionally rigged.
Why not just use a smaller mast or rig it to the top?
Masthead rig is less adjustable, but is a good choice for strength in a cruising yacht.
Particularly building up the crew's strength if you have to tack a lot!![]()
2) a fractional rig has more easily handled genoas, and often a taller mast,so its 'a bigger main' rather than a shorter jib
Due to the unsupported upper mast some fractional rigged yachts also need runners to give added support to the mast and rig, n addition to the backstay, so not a simplified rig either.
ianat182
Not so sure that just because something originated in racing - although in this case it actually did not - many older designs were fractional for reasons other than adjustability, does not mean it cannot be adapted to cruising applications. "Conservative" cruising fractional rigs are not the same as full blown racing rigs with complex staying and runners etc necessary to keep them in one piece.So if it is good for racing I can understand that but you see it on so many boats that are generally cruising and never designed for racing.
The changes have generally been driven by a cruising yachtsman's needs which have themselves been compromised by the technology available at any one time. Back in the '70s we all carried about 4 foresails of different sizes until furling genoas became available, which made the masthead rig manageable up to quite large sizes with a small or weak crew. At the time, stowing a large mainsail was difficult, but lazyjacks, StakPacks and fully-battened sails, as well as furling mains, have meant that there is almost no limit to the size of sail we can cope with.
But is there really a direct correlation between having a masthead rig and a big genoa? While small mains and big genoas were in favour masthead rigs were, too, I suspect. What's to stop a masthead rig having more of an emphasis to the main (i.e. a shorter/steeper forestay and longer/shallower backstay)?
ianat182
