VicS
I take your point about the polarity.
However, the rate of corrosion suggests very strongly that there is an impressed current across the anode and the shaft bridge seems to be the only possible source. What is needed is information about the voltages at various points, so I don't agree that disconnecting a few wires and waiting to see what happens is the correct approach. At the very least the OP needs to replace the anode cable with a meter, checking with and without the engine running. My suggestion of checking the voltage across the flexible coupling also seems valid to me.
Yes ceratinly carry out some checks rather than waiting to see what happens but what little we know suggests that things may not have been wired as they should be.
Firstly, therefore, get everything wired correctly and then check for current flows.
I'm don't know off hand what sort of current flows would be normal but at least with a measured figure one can calculate a likely rate of loss of zinc etc. ( polarity of flow also being important to know)
OTOH some measurements on the system as it is a present might reveal some other issues to resolve.
Measurement of potentials relative to a silver /silver chloride reference electrode is probably the right thing to do. Any deviations from listed values then requiring investigation.
