Why are radar mounts so expensive?
EugeneR
21 Aug 2009
Ocean
I paid £200 for a radar but seems that I will need another £200 to be able to mount it?!
People think you are rich when you have a boat. Clearly, when you have a radar, you must be super-rich!
Surely there's a cheaper alternative?
You think 200 is bad? We want to mount ours on a transom pole and it's closer to 800 - for a white anodised aluminium pole and a swivel mount that screws onto the transom!
The Scanstrut pole is a well-engineered solution, easy to fit, and it looks right.
All true, but 800 quid is still a hell of a lot of money for a white anodised aluminium pole and a couple of cast brackets! Many, many years ago I served my time as junior fitter in a small engineering shop and we used to make things like that - long before CNC machines and all the modern gear they use today to churn these things out.
Sounds like you need to dust off the calipers and make one more, then :)
If I still had access to a machine shop, I would. Used to make fr more complex things than that from scratch, carving them out of blocks of steel by hand the man's way! I really enjoyed it - pity it would not pay as much as bidding for large government IT systems!
It's a nicely engineered system - take a look at the detail next time you see one on a boat. And it's very solid, neat, a good mount for the GPS antenna, etc, and folds down quickly if you want to get at the radome easily. Here's mine...
As a slightly more serious suggestion, could you not get some small (perhaps non-marine) workshop to make one for you? Presumably your prior experience would make it easier to design the thing and to effectively communicate what you have in mind. Thereby perhaps saving a few quid in the "being dicked about by the non-specialist public" fee that I suspect such places quite reasonably add on.
Very nice! But I would still have hand carved one in a couple of hours (probably less) on a decent lathe and a milling machine... We used to build small turbines by hand - I cut the main shaft out of a large steel ingot on a manual lathe. A machine shop of half a dozen men would turn out around ten turbines per day.
I have wondered - may get some quotes. The trouble I would anticipate is finding someone that will make it in ally - most of the custom built examples I've seen are made from stainless steel and, between the cost of the materials and the difficulty of working stainless, I'm not sure that I would save much money.
Take some measurements, do a simple drawing and get a non marine fabricator to make one. Ours is in stainless 3 inch tube and cost £220.00 all in. PM me if you want the firms details.
