BurnitBlue
I am asking about threaded blind keels not through bolting with a nut on the bottom end. Is there a mechanical reason? The only reason I can think of is that a stud is "wound" into the keel with no tension, then a nut is wound on to the top of the stud then tensioned with a socket without rotating the stud.
In contrast a bolt is "wound" into the keel and tensioned with a socket. The threaded part turns with the bolt unlike the stud which stays as it was while only the nut turns. I am thinking that because of this a bolt may strip the thread in the keel while being tensioned whereas a stud will not.
I must change the keel bolts so I am considering 24mm bolts rather than studs. Easier to remove without the hassle of an extra lock-nut where the flanges do not line up
Thanks.
Thanks.
