Who looks at the sky for a weather forcast
DAKA
7 Jan 2005
Nomadic
Does anyone think looking at the sky is the best forecast and best to ignore the nonsense spouted on ch16 ?
Does this say anything to you ?
Did we get a battering the following day or have a great day on the beach at anchor ?
High level Cirrus clouds indicates an approaching warm front.
However due to the nature of the air mass, this can be quite away in advance.
At some point in the next 24 hours you will experience a front passing with a drop in pressure, cumulus nimbus clouds with rain, accompanied by strengthening and veering wind.
Once the front has passed you can expect low level stratus or nimbostratus cloud with persistent light precipitation, an continued slow drop in pressure but warmer ambient tempteture
Does every cloud have a silver lining?;)
A wonderful day on the beach until around 16.45 when it got a bit breezy, followed by periodic showers from 1930 until it hoofed it down at 22.15.
Wot 'e sed.
SWMBO is a compulsive weather watcher, so I just ask her. Usually it is either raining, or just about to rain.
Well done whitelighter and Taz.
Clearly I need to do some research and learn about the old ways.
The sky was striking, far more than my blackberry managed to capture.
The Solent was void of pleasure craft save the odd sailing boat sporting bright orange storm jibs :rolleyes:
There were indeed down pours that evening, the sun was shinning the following morning (intermittently) and we had a great day on the beach in a sheltered anchorage which most likely hid the strong winds forecast by the met office.
That evening the wind veered and the anchorage became very uncomfortable and we had to move early hours.
A fitting folk lore for this is "mare's tails and mackerel scales make tall ships take in their sails" but as pointed out earlier it may not signal a change for another 12 to 24 hours.
Once the frontals system arrives and rain starts, another fairly reliable saying is "rain at seven dry by eleven." It works well on average as 4 hours is about how long a front takes to pass.
Slight admission...........nothing to do with old ways or sailing experience...........I'm a roofer and watch the skies to answer "Should I or shouldn't I cement those ridge tiles tomorrow?":eek::D
Once the front has passed you can expect low level stratus or nimbostratus cloud with persistent light precipitation, an continued slow drop in pressure but warmer ambient temperature
I would only like to correct you on one point it should be:
"At some point in the next 24 hours you will experience a front passing with a drop in pressure, cumulus nimbus clouds with rain, accompanied by strengthening and backing wind."
when the wind veers away, it weakens in strength and you get the famous "Showers, Clearing, Cool" (read black forecast on a barometer). :)
