WHo had the lowest pressure last night?
dralex
9 Jun 2004
South Devon
The barometer fell as low as 965 last night- it was almost back to starting again at " FINE". What pressures did others read?
Torquay was ROugh, ROugh, ROugh- huge waves. I almost couldn't walk along the pontoons at the marina they were moving so much. The storm swell was getting under the harbour walls and blow holing up through man hole covers.
Hope people haven't had too much damage and get things sorted quickly.
<hr width=100% size=1>Life's too short- do it now./forums/images/icons/wink.gif
Rob_Webb
20 May 2002
Auckland
Did I have the highest
My theory about opposites may have applied with the storms and low pressure in the UK and the flat calm and high pressure in NZ.... in Auckland at the weekend we hit 1040 hpa
Nickel
8 Nov 2003
Solent
985 in Winchester, but I saw one of the barometric sites was reading 953 over the Scillies - now that's low!!
<hr width=100% size=1>Nickel
Being paranoid simply means - having all the facts.
tome
28 Mar 2002
kprick
www.google.co.uk
One or both of us needs to calibrate our barometers. A 5 mb difference between Winchester and Petersfield would have removed a loose toupe or two!
Nickel
8 Nov 2003
Solent
Go on, give it a good tap.
To be fair mine's just a kitchen interest barometer - not for forecasting purposes, so I reckon give or take 5 would be about its measure of accuracy.
Mind you a 5mb difference between here and Petersfield, isn't far off a 20-25 mb between here and Devon = windy!
AndCur
9 Oct 2003
The people with the lowest pressure must have been people like me who's boats were out of the water out of harms way!
Nickel
8 Nov 2003
Solent
Ah, well now you have to wait for a period of high pressure, and with a careful application of dexterity solder and blow torch, you should be able to make the needle stand straight out through the glass. Very impressive talking point then!
Interestingly, my daughter is doing a weather project and has found <A target="_blank" HREF=http://www.gbtgt.plus.com/72hourgraph.gif> this site </A> in Otterbourne, not too far away from me, and a wee bit closer to you.
