Mark-1
Who designed the Leisure 27SL/Mirage 270???
TIA.
TIA.
I think that the Mirages built in the UK were a different designer. Can't remember his name though.
Got it!! David Feltham.
Dave feltam is still around, he designed the Snapdragons for Thames marine & Cobra range amongst others before going to Prouts & designing most of their range as well. I dont think he was responsible for the 2700, i will ask him when i see him next.
I worked at Thames marine in 79-80 & helped build the very first Mirage 2700 it was based on a mirage 28 hull with retrousse stern lopped off & the bilge keel stubs were moved slightly, the chief difference was in the new raised deck moulding that was somewhat different to the hull & caused us huge problems fitting the two together!
As for the designer i cant remember his name but he used to wear cowboy boots!
Is this any use to you?
http://www.yachtsnet.co.uk/archives/leisure-27/leisure-27.htm
C_W
Apologies, thought previous reply dident work.
C_W
