mickp
Thankyou to those who replied to my previous post on the white smoke problem. I have so far replaced exhaust system, had injectors and fuel pump serviced, tried without air filter, altered pump timing advance and retard, none of this has made any difference. The oil is good - no water, the cooling is ok levels not gone down, engine starts first time every time, runs well, temp and oil pressures perfectly normal, from this i assume that compression must be ok, head gasket must be ok. So what else can i try ??
If i continue to run engine when all is as above will it do any harm ?
Engine is a Thorneycroft T90 / BMC 1.5 Deisel
