Ian_Edwards
The fuel pump failed on the Piccolo generator.
It's a Magneti Marelli, MAM00008, as per the photo.
It's a very common type of pump, used in a whole host of cars, with a wide variety of equivalent pumps available.
I'd like to know what the flow rate of the pump is, and how many amps it takes at a nominal 12v.
I thought that because it's so common, simple things like flow rate and power requirements would be easy to find online, but so far I've failed. I just get lots of advertisement's to buy it or an alternative.
Fault finding the pump was difficult, the generator would run for 20 to 30min then stop, so initially I didn't think it could be a faulty pump.
However, it turned out that the generator was being gravity feed from the main diesel tank, with a head of about 600mm, and although the gravity flow was enough to get it started, it wasn't enough to keep it going continuously.
Knowing both the flow rate and the power consumption, would have helped.
