single
I hate doing bits at the top of the mast so i want to replace the tatty fibreglass one while i'm there doing the anchor light. SO which aerial to go for? I have read the fibreglass type are better but which one?
I'm replacing the lot including the radio, so it should be fine.To make life easier i'm putting it on the mizzen which is about 10' lower than the main.It won't affect range that much will it?On the whole, new is good as cable and connections do deteriorate with age. Incidentally, I was thinking of the sea god Neptune. An antenna effectively propogates a horizontal dish of energy, so when heeled the windward side is inclined toward the clouds and the leeward side to the waves.
Rob
About three miles less range, all other things being equal.
+1 for the Metz. Fab antenna...
John, I am glad that you are selling now the Metz DSC antenna for ICOM M802/1.About three miles less range, all other things being equal.
But I can not follow your calculation of the reduction of the radio horizont.
I am using
Distance (in nm) = 2.5 x sq root (High in meter)
Then I get for the 10 feet reduction of mast high from 16 to 13 meter a reduction of 1 mile in radio horizont
High Root 2,5
13 3,61 9,0
16 4,00 10,0 <<< this may work for a short check
18 4,24 10,6
21 4,58 11,5
24 4,90 12,2
27 5,20 13,0
30 5,48 13,7
33 5,74 14,4
36 6,00 15,0
39 6,24 15,6
Greetings, Wilhelm
