Which tool
ripvan1
20 Jun 2011
Pompey
would I use for this not possessing a router or dremel?
The cabin floor is foam cored and I want to remove an area of the inner fibreglass coating to get at the foam, remove and replace. Obviously I don't want to go right through to the outer skin so a depth of say 3-4mm max ix only required.
Is there a router bit to fit in a drill that will do this, or would a well worn angle grinder disk do the job
Amulet
25 Jun 2007
Oban
www.flickr.com
Hire a router - or buy a wee one. you'll not regret it.
Gwylan
31 May 2007
Moved ashore
Possible?
Bosch 180E - versatile tool, cheaper than the Fein.
The Bosch is my favourite for most of these type jobs - or a Dremel clone?
You can cut out panels and 'stick' them back
prv
29 Nov 2009
Southampton
Yep - or better yet (from a budget point of view) the Aldi knockoff of the same tool. Reckoned on uk.d-i-y to be just as good as the Bosch one, but cheaper.
I've used mine for exactly this job, replacing the sodden core of the aft deck.
stav
7 Aug 2002
Jersey
Not a router bit in a drill: limited control and to sharp to be near digits.
Have a similiar job looming and will be using a fein with abrasive disc cutter or angle grinder with a fine cutting disc, from previous threads I gather metal discs work best.
Good luck with it.
[27631]
N/A
5 Sep 2007
Hi Steve...
I am still stuck in Gib. sorting this engine...anyway..1/8" plasma metal cutting disc with a wood spacer block is probably the cheapest option...dont put too much pressure on these thin discs though...they shatter and break up...all the best...Ian.
Bav32
26 Dec 2009
Have a look at
http://www.youtube.com/watch?v=1Od1aDT4GIQ
These guys cut the outer skin off using a hand held circular saw to gain access to the wet balsa core underneath.
Obvoisly you have to experiment to set the cutting depth and suspect it was a tungson carbide tippped blade.
So if you don't want to buy fancy tools and cutting disks etc, thismight be an option
ripvan1
20 Jun 2011
Pompey
thanks again for replies, ian, how's the engine going - are you m the move yet? don't quite comprendo what you and another mean by putting block on grinder - ?
prv
29 Nov 2009
Southampton
You only want to cut through the top skin, not right through the whole panel. I assume they mean somehow clamping a block to the grinder to act as a depth stop.
[27631]
N/A
5 Sep 2007
as prv says....
'You only want to cut through the top skin, not right through the whole panel. I assume they mean somehow clamping a block to the grinder to act as a depth stop'....exactly right...so about an 1" thick block would do it......and ...
yes still stuck in Marina Bay..should get the bits I need by air freight by Thurs or Fri...so hopefully I can get away from here then...
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
When I took out a rectangle of the inner hull skin on my Sadler to fit the backing pad for yacht legs I cut them with a padsaw. Very easy work and no risk of going too deep. I assume a floor might be more heavily built than the inner topsides but probably not a lot.
