With that in mind - I would turn the dial to the left, then briefly (on an unused channel) transmit with the switch in the SET position. Whilst transmitting, the dial can then be used to 'zero' the needle. Stop transmitting.
The switch can then be moved to the 'ROS' position and a further brief transmission used to read the SWR from the top scale.
ROS might be Italian or French for SWR - but think of it as Reflected Outgoing Signal ratio for ease..
The link below is to a short, 23 second video (on OneDrive) that I made (albeit on a meter with Power, Calibrate and SWR settings) showing measurements of forward power, reflected power, then a calibration (to top end of the scale) and finally an SWR reading.
