which rollers
mbay
3 Jun 2003
North East England
I have a set a of fluffy rollers ready to antifoul my boat but have been informed that these are the wrong type????do i nead the sponge ones ????or does it not really matter.?? /forums/images/graemlins/confused.gif
One problem with the "fluffy" sort is that when loaded with paint they weigh a ton and knackering to use after a while. I've tended towards using little radiator rollers for a/f.
Or be a "high roller" and get the yard to do it /forums/images/graemlins/cool.gif
dont think it matters really but i find a foam roller gives a better surfaces finish. and does not soak the a/f up. i use a 3 inch roller it takes longer to do th boat but you dont waste too much A/F
main problem with a fluffy is the amount of paint wasted in the roller
A lot of people use the radiator roller which is about 3" and on an extended arm (abt 18")
Personally I use the cheapest B&Q gloss roller and tray combo,and then use an extension piece (abt 4 ft) and find that that is the quickest and easiest on my back.
After finishing I throw the roller and the tray away.
Don't use the fluffy ones. When the paint gets sticky it will leave hairs sticking out of the antifouled surface. Marine growth will use it as its foothold.
You can use either, but I have found the sponge rollers disintegrate fast with antifouling.
As others say, a long handle and small rollers is easier.
Don't even think about cleaning, just chuck it all in the appropriate bin.
Wear safety glasses and a fume filter if you can find one (I couldn't).
Fluffy rollers = thick and not very smooth finish but quick job
Short hair roller = thin and smooth finish but slower job
Take your pick.
You have to use foam rollers designed for solvent based paint. They do vary in quality, some poor some very good, I couldn't say which make is the best, I wish I knew myself.
I use whichever rollers my son brings with him when he comes to help, then I usually feel tired after about 10 mins and leave him too it!
A good idea is to protect the paint tray with a plastic bag, when you have finished painting the roller can be removed , wrapped in the bag, and then binned without getting much paint on your hands and the tray doesn't need cleaning!
The 3 inch ones made by Stanley tend to perform best IMHO. The cheap B&Q ones fall apart after doing one side of the boat (Sigma 33) whereas the Stanley ones will do the whole boat and still be OK. I usually thin the paint down approx 1 litre of thinners to 2.5lts of paint. Put on four to six coats for an outstanding smooth racing finish.
