Which prop for 2000 fletcher 19 GTS with 3.0l
Mk2zetec
New Member
20 Aug 2017
Eveinjng all
I need to replace the prop following some damage - it currently has a Mi-wheel 15x17 but my googling suggests it should be running a 19 pitch
Is it worth getting a ss steel prop?
It's used in the sea and for pulling inflatables as well as cruising.
Many thanks
Rich
Eveinjng all
Many thanks
Rich
Welcome Rich
Is it a 3l Mercruiser with a Alpha 1 drive? If it is I think I might have my old propeller in the garage and tomorrow I could go have a look at the size.
I used to use mine in a river and would occasionally ding the prop so I never bothered with expensive stainless steel
Ok I've dug them up and
15inch (actual size 14.5inch) and a 21 inch pitch
The code stamped on the prop is
48-832832-C1-21 A15
That prop was good for nearly 45mph on a river with a SeaRay 175 bowrider with 3 or 4 people on board.
Changing prop sizes is a dark art that others on this forum are more knowledgeable but my advice is go to a supplier that has several old props in stock that they can lend to you to experiment with
Good luck
Hi, I am looking for the same - prop for 19gts (merc 3l). Mine has one that is too large.
Meec prop locator says 14.5 diameter, 15 pitch. Part #16312A46
Hoping to use the boat for wakeboarding and skiing as well as run about the coast.
I welcome your suggestions/insight/experience, 2nd hand props.
With thanks in advance
Ned
