DHV90
Hi all,
I need to source a dome nut or lifting eye nut to go on the end of a 1/2 inch bolt buried deep down in the stem of my boat, which is inside a small well in the foredeck. Due to the location access is absolutely terrible and I can barely get at it with verniers to measure and a thread gauge won't fit on. Im going to hedge my bets and order one or two to try. Is BSF most likely or could it be UNC/UNF? Any input much appreciated.
The boat is british built, around 1980 and the bolt is part of the rigging effectively, a series of glassed in bolts to which a channeled piece of stainless is secured to through which the forestay pin goes.
Lifting eyes seem to be non existent in imperial so the current plan is to drill the top of a dome nut and stick a shackle through, I need to run a short length of dyneema up to deck level to secure the tack of the sail and because of this weird shaped well there is no where else to connect it thats not either a few inches too far aft, where the deck starts, or infront of the forestay!
