I've never used it for that, although I have heard that it works very well. I have a Windpilot, it came lubricated with tallow and the instruction book advises using the same thing subsequently.
I must say that this contradicts my normal philosophy, which is that the only natural product better than man-made is shoe leather. My seacocks are lubricated either with a calcium-based heavy grease that I have owned for years, or silicone winch grease.
Hmm, I posted a reply here but dont see it.. ah well.
FWIW I had a small tub of blakes seacock grease, sort of very light green, used that, excellent.. ran out and used lithium base, also excellent..
while you are out lap the tapers in with valve grinding paste first, clean, then apply grease.
JOe
Blakes seacock grease is probably the best option - pricey for the size of pot but will last a few seasons. Most chandlers will stock it
blast, a lakesailoring
Yep, definitely Blakes Seacock grease. And a pot will last for many years unless one plasters the stuff on!! I guess I buy a pot about every 10-12 years, but only have 5 seacocks, which may be the reason. But then I use it for loads of other things e.g. the bottlescrews, removeable log assembly etc!
Medical-grade anhydrous lanolin. Low-tec and simple, like Blakes Valves. Originally sold as waterpump grease. Its cousin stops ducks getting wet or sinking; kept sailors' ganseys waterproof, and also, being a semi industrial product, HAS to be cheaper than anything yotty. The "medical" term just means it's been strained clean of wool.
I have a jealously conserved pot of Dukchams Keenol, which had worked for me, but I have hedged my bets and also laid in a pot of Blakes. Both pots should see me out.
