Which furling gear is this?
PlankWalker
2 Feb 2010
South UK
The gear is on a Dutch built boat, so possibly hails from that neck of the woods.
The drum needs to be raised a foot or more above the deck, and it would be nice to know how it's put together and weather I need to dismantle the top the bottom or both.
Any advice would be greatly appreciated.
@PlankWalker is this your boat, please? I have the same furler, and the stainless steel cover (over the drum upon which the furling line is wound) has popped out of position a couple of times, interfering with operations.
I am in the middle of composing an email to the manufacturer, but their website hasn't been updated in years and have just found your thread.
There appears to be a groove just above the top of the cover (above the black part) into which some kind of circlip might fit, but I see yours is the exact same, with no retainer in the groove.
The video is clearer, although you might need to press the full-scree button:
EDIT: for the sake of Google, the furler was made by Heino Haase Segel, a Haas Reff-2000
Hi CompetentKrew,
Its actually my boat, " son of plankwalker" van de stadt seal 36 from late 80s, i actually had exactly the same problem when i bought her, i made a little bracket if i remember correctly that came off the feed arm with a hole in that allowed that long stainless pin you can see in your video to go through, with a hole in said pin for a split ring. This not only kept the drum aperture in the correct orientation to the feed, it also stopped it jumping up and down in a short sea. I've done a lot of miles since then and never had a problem since. I will be down over the weekend and take a picture.
Thanks, @lonederanger. There's actually a hole for the pin to go through already, but no way of retaining it there. I thought about threading the pin, and then a nut on the end would secure it. I don't know whether this or a split pin would be better.
I'm fascinated to wonder what the manufacturer intended - I emailed them 24 hours ago but they haven't yet replied (from the dates of the updates on their website, I fear they may never do so). What is that groove for, if not some kind of retainer?
