I have finally got fed up with my dripping filter. Can anyone suggest a replacement? 20hp engine. prefilter/water separator, glass bowl, cheap replacement filters........must not leak! Thanks.
CAV filters are dirt cheap, but IMHO, the aggro in changing them is worth paying a bit more for spin-on filters. I'd hate to have to change a cav filter in a hurry and a lumpy sea, which is when you're most likely to need an unscheduled change.
After having to come into Portsmouth with a dead engine a couple of weeks ago due to the crap in my tank being stirred up by a rough sea, I struggled for a couple of hours to persuade all the sealing rings in my CAV to seal properly & I still haven't got the stench of diesel out of the boat.
Plan A for this winter is a couple of transit or similar filter holders from a breakers plumbed in parallel so I can switch to the the other in a few seconds if the first one dies, and change a filter with one hand if I need to.
Don,t like the sound of the CAV if I end up smeared in diesel. Roughly how much are the Racor replacement filters? (my Separ jobs last a long time, but they are sixteen quid!)
Racor are designed for long use with many hours! very few boat do the sort of hours that would require the replacement of a filter! unless the fuel is contaminated then what price to sort out ! I have two racors (large ones) and yes there are cheaper filter elements but I wouldn`t change mine for all the Diesel in china! I last purchased a pair of new elements at Beaulieu for a tenner! so buy a Racor and just keep an eye on the state of the element and don`t relace it because the engine manufacturer tells you to! wait until its necessary.
The Racor Turbine filter's centrifugal effect requires the larger fuel flow demanded by a big engine (and the filter's rated for over 200 litres an hour!). Unless you've put a seriously big engine in your Contessa, it'd be a complete waste of your money. If you can't be bothered with the minor inconvenience of changing CAV-type filters, why not get a small Racor Spin-On 120?
get the small racor with the built in hand pump. If you happen to get a build up in the secondary filter or an air leak in the system ,the pump will keep the system primed.a useful get you home
addition.
I changed my CAV filter recently, it has the glass bowl under it. Is there a special knack to getting them to seal because I had a devil of a job and ended up re-using one of the old rubber seals? It was a genuine CAV boxed filter.
With the glass bowl CAV filter, the big rubber sealing rings are 2 slightly different diameters. I think the one which goes in the top of the glass bowl is the larger one. Not all replacement filters are supplied with the correct-sized sealing rings.
Yep, you're quite correct. I found this problem (two rings the SAME size) with the Crossland filters for the CAV296 type earlier this year when I bought 6 for spares. Took 'em back and the retailer and me checked a few more boxes. Most had the two different sizes, so it may just have been a 'bad' batch.
Got the rings changed but it's well worth opening and checking when you buy them and save the hassle!!
IIRC there is also a third o ring, much smaller than the two others (say about 10mm diameter), which goes around a small metal pipe coming out of the filter head
Fleetguard filter (part FF167A replaces CAV296) usually come with the three rings (well sometimes they abound and one find six rings)
Ahh, that would be why, there were three rings, the two larger ones were the same size and one was just too big and kept leaving a small weep, I'll check my other spares. Good job I had the trusty disposable nappies under it whilst I did. I was also considering a different option not relishing having to do this on a lumpy sea.
