hullabaloo
which machine (buffer) compound and wax / polish do you find best for removing and keeping oxidation at bay on a grp hull?
After reading your reply, I have just spent half hour on your web site and i would say you know your stuff, thanks for your advice and i will follow your lead.
Thanks for the tip, will purchase some of this for the more oxidised projects I need to work onCompounding - 3M high gloss
I normally use this first on the boat (after washing, obviously) that doesn't show signs of oxidisation... am I being tough enough? Or should I still be using the 3m high gloss as a compound first?Polishing - 3M Finesse-it finishing material
I was recommended maguires flagship products and have used them.. seem fine but I prefer 3M.has just reminded me of the work I have to do over the next 5 weeks...
Seabird is all polished and looking good, but as for sale I will probably give another coat of polish to keep her looking her best. My parents boat is the PITA, 48ft and a 6ft keel meaning scaffold tower, just seeing my pics in the other thread started my arms aching.. re-launch is booked for 9th March, and I'm away on holiday for 10 days in between now and then.. oh gawd
Then my new to me Mitchell has a navy blue hull & is in the water and to get up to my standard needs a full compound and polish. She's still at Porto Solento at the moment on one of their stupid spring board tiny pontoon berths with just over a foot clearance between us and our neighbour so cannot get a dinghy around the boat to give a decent polish... so at least it saves me a job for the time being, but not surprisingly that's the one I really want to do!
I have been trying a few different products (well to be honest I have been getting a few freebies), Meguiars no.50 and then Meguiars no.45 to top it off. It is made especially for GRP so thought it may be pretty good and I think the Meguiars name is well respected..... I have not really had time to give them a good trial but on the little bit I did use the no.50 GRP cleaner seemed really good. When I use both fully I will report back.. anyone else any views on them??
http://www.meguiars.co.uk/category/217
Thank you!
I assume going by the above link that the last time you polished and waxed you used a very fine polish (G10) and wax, but i'm guessing it has oxidised again?
When I compound with Finesst-It, I polish with Mer's car polish - is this not up to the task of gelcoat?
Wow, so much more to this than I ever realised.
Recently I used Finesse-It (The black bottle) with a medium foam pad. The reason I liked using the foam pad is that i'd compound quite 'wet' in the sense that I would use a water spray bottle while compounding.
It is only recently on videos online i've seen people compound with a wool mat - it just doesn't compute in my mind, but it obviously does work.
What I would like to do is compound with the 3M High Gloss and a medium foam pad, then a dose of Finesse-It, and then Mers Car polish... but from what you say, that wouldn't make sense?!
I am more comfortable compounding with the foam pads (and some water spray), should I be learning to do so with the wool mat?
