TwoHooter
I've done a search and can't find a direct answer to my question so I'm risking someone accusing me of duplication.
On our motorboat I need to create a watertight GRP bulkhead inside the starboard cockpit locker to prevent water from finding its way to the hole up through which comes the exhaust from the diesel-fired hydronic heater which sits below the locker in the lazarette. I want to fit an inspection panel in the new bulkhead so that it is possible to get easy access to the exhaust system. If all that confuses you perhaps this picture will help. BTW, after the watertight bulkhead has been made I will plug the further of the two drain holes.
The inspection panel/inspection hatch would ideally be about 300mm x 300mm but various different sizes and shapes would work.
I have found numerous candidates for the sort of inspection hatch I have in mind. For example:
http://www.force4.co.uk/department/...s-ventilation-lockers/inspection-hatches.html
I tried to reproduce other chandlers' search results without success. Bainbridge have a good selection for example.
Prices vary from less than £50 to nearly £200.
Here's my question: Does anyone have a view on which is the best quality hatch for this job? The hatch won't be directly exposed to weather but I want to know that it is truly watertight and I want it to last at least 20 years, preferably 30 or more. I'm willing to buy top of the range to achieve that but I've no way of knowing whether more money does buy better quality or whether I'll be just as well served by a cheap hatch as an expensive one. Believe me, there's a host of other things I can usefully spend this year's budget on if I don't have to buy an expensive hatch.
