trouville
N/A
Which battery either a normal cat battery or a gel one??
Today the supermarkets are overflowing with gel batteries from China for starting a car,
Compact powerful,they used to cost £100+ and only seen in garages.
Today from £20! With lamp meter compressor and some even have 4.5v 6v 9.6v and 12v out put as well.
Clearly the quality will vary, but for a small boat and for sevices,bilge pump lighting,would it do?
Could it be used to run the auto pilot VHF and Depth?? And how do you recharge them? will they charge by solar panel?Via the out put cabels? or only via the built in charger?
Or is the normal car/boat lead acid better?? or both? One i see hear is a car charger gel battery "600amps" 5seconds?
A lead acid battery is 350 amp hour, (the 600amp hour would upset the ballast in my small boat!!!!)
Which is the best given a 600amp/secons and a 350amp HR cost the same???
