prv
Might seem like a silly question, but I'm not going to be at the boat for a few days so I can't just read what's written on it.
It's a Raymarine wheelpilot, and I had assumed it was an SPX5 as currently listed on their site. Certainly looks a lot like it, same shaped box etc. The connection area looks like the one for the SPX 5 - see this manual ( http://www.raymarine.eu/WorkArea/DownloadAsset.aspx?id=1529 ), page 19 of the PDF which is labelled as page 11. Mine has the same overall layout, the same tabs for attaching cable ties, the same fuses in the same positions. However, there are a couple of differences - mine has a set of terminals for a rate gyro, currently unused, and it also, crucially, has connections for a clutch.
On my long-term list is replacing the rattly wheelpilot bodgery with a proper below-decks drive unit - also useful as emergency steering when you have long twisty runs of steering cable as I do. I was annoyedly resigned to having to replace the whole lot as the SPX5 will not work with a linear drive - but if whatever I have will operate a clutch, then perhaps it will.
Anyone with knowledge of the Raymarine range able to guess what it might be?
EDIT: Figured it out - no further assistance required
Cheers,
Cheers,
