which antifoul paint
ianainge
15 Jan 2003
Hampshire
several people and boatyards have recommended international interspeed ultra antifoul for the boat but i have read that you cant use this on aliminium, i think my outdrives are ali as are my trim tabs or am i thinking S**T?
Chris_d
15 Jun 2001
Oxfordshire
Yes you need a special outdrive paint, all outdrives are ali, there is copper (i think ) in hull antifouls and the effect is like two dissimilar metals in a battery, so the outdrive starts to get eaten away. International do an outdrive antifoul but the colour range is limited, which is why mine is always battleship grey.
adarcy
31 Aug 2001
Yes, quite likely.
But to answer your first question - outdrives almost certainly al-YOU-minium and tabs stainless or al-YOU-minium = not Interspeed Ultra unless you can assure no breaks ever in the primer (ha ha re tabs)
DepSol
6 Oct 2001
Guernsey
You need an MPX paint for your drives and tabs, can get it to brush on or spray on. There is a new one out which is very good but the name escapes me at the mo.
Make sure you leave an inch gap of antifoul around the transom shield when painting.
Dom
Ok so he's not santas Elf but he is an Elf !!
Margem
1 Jun 2001
Leicetershire
Ive just antifouled my boat, used "Seajet" antifoul 30 quid a tin and brilliant. For the outdrives use arosol spray on paint by VC tar, its the correct colour and the spray gets into all the awkward parts dead easy. If existing paint is poor use the primer first. i think its called "prop O derv."
Nothing will grow or stick to your drives when this products on.
DepSol
6 Oct 2001
Guernsey
told it was something to do with conductivity of a/foul and corrosion of anodes, much better leaving a gap.
Dom
Merry xmas and a happy new year
ccscott49
7 Sep 2001
I'm using "seajet shogun" I think it's called this year in the med, just bought 40 litres for about 550 Euros in 20 litre drums, reccomended by my brother, he had it on one of his boats up in morcambe bay, where the foulilng is quite bad, no problems. I'll need it all this year, scraping a bit of the old off here and there, where it's a bit thick and crumbly!
