Which AIS
ITH
28 Jan 2005
Winter in Kent, rest of the year on board
Thinking of installing AIS to display on existing Standard Horizon chart plotter. S.H. says that its chart plotter will work with any NMEA-compatible AIS engine. It "doesn't recommend specific units" but says that "both NASA and Easy-AIS units are known to work."
Would appreciate opinions from existing AIS users.
There is no comparison with regard to build quality. I believe the Easy is just better quality entirely and incidentally have one coupled to a SH 500 and it's very good.
The build quality of both my units is excellent. Both have good quality circuit boards, good quality connectors and cables. I cannot fault either on performance or quality.
One thing worth noting is that the latest EasyAIS 2 has a dual channel parallel receiver, whereas the latest Nasa AIS 2 engine still only has a single channel receiver, which alternates between the A & B channels. Would also be worth looking at the Comar AIS2, which also has a dual parallel receiver.
Tests we have carried out using the Comar-2-NMEA and Comar-2-USB units show that they perform very well - they are also compact and robust.
Am very interested in the Comar 2 - USB. Have you any idea whether it will work with Tusami 99 charts/software?
Tsunami 99 is from a pre-AIS era - so unfortunately it does not work. Anyway, the Comar-2-USB is a great unit and by far the simplest to use with a PC. For a plotter, the EasyAIS is great.
Thanks for that. /forums/images/graemlins/smile.gif It's a shame because I don't have a chartplotter and an 'add-on' would have been useful for the occasional channel crossing in fog - the only time I'm likely to have used it.
The T99 stuff works beautifully on my laptop too! /forums/images/graemlins/frown.gif
Make sure you get the benefit of the latest version by specifying EasyAIS 2 - the original EasyAIS wasn't a dual parallel receiver.
I went for the easy ais 2 a couple of months ago. very pleased with it and it works very well with th SH chart plotter. for the extra £30 it seemed to be a low marginal cost.
what's especially surprising is how soon you come to rely on it.
