Where to get a replacement stud?
DavidMcMullan
19 Jun 2003
Bangor, N.Ireland
Does anyone know of a source for a replacement stud, for a dinghy oar? This is the sprung stud that locks the two sections of oars together. I have the spring, but the stud popped out, did a triple somersault and disappeared into the sea. Thanks, David.
If you manage to find one, before fitting it examine the hole in the oar. These become enlarged after a while due to galvanic corrosion between the stainless stud and aluminium oar, allowing the stud to fall through. I made a few washers from polythene to overcome oversized holes in mine.
Vyv - Yes, that is exactly why it fell out. The circular hole has become ragged due to corrosion, which allowed it to pop out. Thanks for the tip about a non-metalic washer behind. David.
