contessaman
Hopefully this question isn't as stupid as it sounds....
Bowman oil cooler - for the engine not transmission oil.
Where should it sit in the cooling circuit? I've seen several permutations. Should it have raw water flowing through it? Or will this prevent the oil from getting warm? It would seem to me that it would be better somewhere in the freshwater cooling circuit, cooled by water maintained at a sensible temperature. But even here there are options as the water leaving the heat exchanger stack will be at its coolest and water that's just been through the block at its hottest.
I can draw a list of pros and cons for each option but there must presumably be a convention?
Grateful for all your thoughts on the matter....
