Wheelhouse mould (or mouldings) wanted.
Tanqueray
26 May 2011
Does anyone know of any wheelhouse moulds kicking about or somebody who can produce mouldings for me?
Something along the lines of a Fisher 46 or Rhea 850 is the sort of thing I'm after. It's a one-off project and I can laminate / modify myself if required or someone can just work with me on the design and then produce the mouldings.
Pm if you like. Ta.
(Yes, I can do it the long way round but I'm looking for a short-cut to speed things up if poss).
Welcome to the forum.
I built ours, helm station, in foam, bends easily, upto a point, easy to fair, (when you cannot bend) then glassed inside and out. For windows you can cut a hole, recess the edges and then bond acrylic. If you want opening windows or doors piano hinges and braces or variable struts. Finish with a 2 pack spray.
To get a perfect fit when you have the 'almost' complete unit before you spray paint:
Using packing tape where the unit meets the existing structure, so tape stuck to existing deck. Turn unit upside down and trowel on a thick, non drip, layer of filled epoxy. Plonk unit onto tape (needs 2 or 3 people) the filled epoxy will then take up the exact form of the junction. Remove excess, use it to fill where it is a bit thin. Leave to set off. When set - lift off - the epoxy will lift cleanly off the packing tape. Fare back to shape/finish you desire and reinforce with glass tape. We had ours as a flange and when completed could attach finished unit to chosen location using Sikaflex and screws attached to the existing gelcoat.
Its not quick. Foam is easy to work with, you can carve it with a carving knife, and much lighter than ply. Its easy to make alterations. Glassing the foam unit can be fiddly at the corners - you need a decent place to work - garage, big garden shed. For spray painting I built a polythene tent and sprayed from the outside (the fumes are lethal) and get everywhere.
I found it an immensely satisfying exercise but convinced me not to build a catamaran at home - fairing a helm station was acceptable - fairing 2 x 40 hulls - no way. We had fitted 1m extensions to the transoms a couple of years earlier, similar technique - except to attach we ground off the gel coat for 800mm forward of the existing transom to give a large overlap - and then attached the foam 'shoes' and glassed the shoes to the hull then filled and faired.
Jonathan
. . . and another more recent model built from ply encapsulated inside and out with West Epoxy.
. . . and no movement with my 13 stone on the top marking out the electric sunroof.
You could as easily make from foam which would allow you to curve the roof - the strength will be determined by the thickness of foam and the weight of the glass.
Jonathan
All the one-off mouldings in my boat were made using female moulds made of faced MDF and curved with plasticene or for larger curves, filler and ever larger curves, thin MDF bent and framed. There's no reason why a female mould couldn't be made for an entire wheelhouse. As long as the design is right it needn't look like a slab-sided refrigerator.
