Sandyman
In my berth I run the engine under load (i.e. in gear) an 30 mins later the chill had been taken off the not "hot" water
Are you running the engine at the same revs in your berth as you do at sea ??
Im looking along the lines that the stat might not be opening unless water hot enough and hence little flow through the calorifier coil.
Just a thought.
Just a thought.
