Often sail past it going into Bradwell. I think it is called the training wall, suspect it is also possibly the cooling water outlet for the power station. It's why it's that funny glowing colour. That photo was actually taken at night.
I don't think this is a training wall at all. It is the water inlet /outlet for the power station. The nuclear power station ceased working some time ago and I think it is in the long term process of being decommissioned.
The structure has the normal two vertical red lights at each end. If you are shallow draft you can go inside it and I have seen boats anchored inside it. If you are looking for the entrance to Bradwell marina in bad weather it can be a bit unnerving to come across the wall unless you know what it is, and then it is a reassuring sight.
It is the baffle. As said above, the water inlet/outlet, now very rusty. The station is now defuelled, but whether cooling water has stopped being pumped around, who knows?
I think it's an old photo, probably when the station was operational. Just across the river is West Mersea, where I live, and my house doesn't show our conservatory which was built 5 years ago.
When i was stuck in Bradwell once(bad weather) I did the tour of the power station.The water coming out of the outlet is 15degrees warmer than when sucked in.Hence the size of fish at the Green Man Pub
They started to dismantle the wall but stopped.Rumour has it that the station is mothballed but may be be in line to be active again depending on how the nuclear/energy arguement goes.
Baffle - takes in cooling water on one side and pumps it out on the other - keeps the two apart so the power station doesn't suck in its own warm water - so I've always understood.
